I need help advice and steps
GLiffjOhn
Hi guys im new in this forum and i just build my 1st gaming desktop last 2-3 months ago.
I just wanted to know all the steps for OC my CPU! Pictures of the bios is more help if you guys can provide it for me!
Also can you guys give me an advice on which SSD should i buy. My target is 80GB to 120GB. Most people says that SSD is betterthan HDD.
Im using my PC to play Ran Online game and Soldier Front of ijji. Reason why im switching to SSD is because im having a slow
loading prob in Soldier Front.
These are my current PC specs:
intel i5-2500k
ASUS Maximus IV Gene-Z/GEN3
CORSAIR Enthusiast Series TX650 V2 650W
G.SKILL 4GB (2 x 2GB) 240-Pin DDR3
EVGA SuperClocked 01G-P3-1563-AR GeForce GTX 560 Ti (Fermi) 1GB 256-bit
OS i windows 7 ultimate 32-bit
im using 32-bit OS cause the ran online game im playing only works for a 32-bit OS
Hopefully someone can help me here and provide the pictures for OC my CPU also i dont have a after market CPU heatsink any suggestions aswell
Please help me guys..
one more thing to mention i have this issue about my CPU before it says over temp that time i was trying to disable the Speedstep and C1 etc. at the bios probably i did something wrong.
Thanks guys
Cooler Master HAF 922
Samsung 830 128GB SSD
500GB W'D Caviar Black HDD
G Skill Ripjaws X (2x8gb) 1866
Intel i5-2500k @ 4.5mhz 1.270vcore
ThermalTake Frio running at 1300-1400rpm
EVGA SuperClocked GeForce GTX 560 Ti (Fermi) 1GB 256-bit
4 REPLIES 4
HiVizMan
Level 40
Hello my friend.
There are some guides for your motherboard that can be found in the Maximus sub-forum. Have a read through them and decide which method you want to try. But basically it is real easy to do. Just keep an eye on your temps and you are good to go.
Hey sir can you post the link where i can look at the steps how to OC my cpu?
and quick question raiding SSD is like im still using my HDD as primary Hard drive and the SSD is going to be the cache for my HDD? im cofused @_@
I found these 2 links
1st link: http://rog.asus.com/forum/showthread.php?11120-Overclocking-The-Core-i5-2500K-With-Maximus-IV-GENE-Z...
do i have to just copy that image of his bios set up?
2nd link: http://rog.asus.com/forum/showthread.php?11581-Intel-Smart-Response-Technology-User-Guide&country=&s...
is this the way to do the raid thing for SSD in my bios? should i just copy the exact bios set up he had in pictures he showed?
HiVizMan
Level 40
Hello again - yeah that is about it just bare in mind that each CPU is different but for 4.4GHz that will be fine.
SSD and OS
How big is your SSD? If your OS is on the SSD then your system performance will be much faster than if you have a system cache on SSD.
