How to prevent default installations on C-drive?
TenBlade
Level 11
Certain programs do not give you the option for custom installation, forcing them onto C-drive, hence C-drive space shrinking. And SSD's don't have an abundance of space, not in my budget.
So, is there a way to override such an installation on C, to have only elements essential to OS on C?
13 REPLIES 13
Paulovrv
I have the same question!:)
G75VW-BHI7N07: i7-3630QM * 32Gb ram Crucial * Windows damn 8 PRO
Kingston HyperX 3K 120 SSD + 1TB hdd (sad 5400 rpm)
Chino
Level 15
It's pretty easy to change the default installation path via the registry.
1. Launch Registry Editor.
2. Navigate to HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion
3. You'll see a value named ProgramFilesDir.
4. Double click it and change it to the location you want.
Note: For 64 bit users, you'll see ProgramFilesDir and ProgramFilesDir x86. Change both of them.
Tks!! So easy and so useful. As everything should be!
TenBlade
Level 11
Thanks, Chino! repped!
Adding this to "must do" list for new installation.
Myk_SilentShado
Level 15
You can do as Chino suggested, or you can go the much easier route - provided the software allows it, is do a "custom" install, which should allow you to pick where you want your software installed...I have yet to find any software that doesn't let me choose where I install my crap lol 😛
TenBlade
Level 11
That´s just the thing, Myk, some programs don´t present me with the custom option.
from my experience, you should avoid those programs
TenBlade
Level 11
I´ll try to filter what I can on my next rig, but with the relatively easy fix provided by Chino, I hope I won´t have to leave out any "must-haves". I don´t suppose the registry tweak presents any danger to my system (stability issues, programs won´t work etc.)?!
shawnavonsr
If they do install on C: you can do this to move them *banned website*
Also if like me you like to keep the SSD with as little installs. I use steam mover to push on and off the SSD to the HDD. http://www.traynier.com/software/steammover
This also works for other programs and super easy to use
