How to connect 4 pin CPU power on maximus vii formula when the PSU doesn't support?
tinnguyen701
I have the asus maximus vii formula and I want to connecting 4 pin cpu power for doing OC but my corsair ax860 they don't have the 4 pin connector, so what can I do now? Thanks for help!!!
8 REPLIES 8
Nate152
Hello tinnguyen701
Depending how far you plan on overclocking you shouldn't need it but if you want it you could get this.
http://www.outletpc.com/c8384.html
tinnguyen701
Hi Nate152, and thanks for your help!!! I just plan but I don't doing OC right now, if I just run with CPU core i7 4790k 4.40 GHz and I just use only 8 pin power connectors on VII formula that's enough power and just fine right? Because i worry when I don't plug in all the power so my system they don't have enough power and they getting trouble. Sorry my English very suck!!!
Nate152
You should be able to hit 4.9GHz - 5.0GHz with just the 8 pin power cable connected.
Really? Cause someone say I need to be plug in 4 pin and 8 pin ,that make all thing is legal , and I don't know exactly the 4 pin connector they design for what?
Nate152
When you want to overclock your cpu let me know, I will help you.
What cpu cooler do you have?
tinnguyen701
My CPU cooler is Corsair H100i . and thank you very much for that !
NemesisChild
Level 12
As Nate mentioned, the extra 4-pin connector is only needed for extreme CPU overclocking.
Intel i9 10850K@ 5.3GHz
ASUS ROG Strix Z490-E
Corsair H115i Pro XT
G.Skill TridentZ@ 3600MHz CL14 2x16GB
EVGA RTX 3090 Ti FWT3 Ultra
OS: WD Black SN850 1TB NVMe M.2
Storage: WD Blue SN550 2TB NVMe M.2
EVGA SuperNova 1200 P2
ASUS ROG Strix Helios GX601
tinnguyen701
And one more question, if I run the Cpu intel core i7 4790k and asus matrix gtx 980 with corsair ax860 so that psu have inough power handle ?
