The max duty only applies when you stay under the max t° limit beyond that it will go to a 100%. If you don't want that, try using speedfan; it should override mobo control of your fans even when still using AISuite. On my CVF it switches back to mobo control the moment I open fanexpert (sensor recorder etc. don't do this). Don't know about your board, but Speedfan is able to control my CPU, CPU_OPT and Chassis fans not the OPT1.2.3 fans.
If that doesn't work, put a 5/7/9.5V adapter on your fan, they're pretty cheap or easy to make yourself. DO keep an eye on your temps though.
Or get another fan or cooler because it sounds like your still using the crappy stock cooler from Intel.
offtopic more or less: Can you lower the t° treshold for the user mode on the OPT fans? Most of my temps never reach more than 45°C so auto fancontrol on the OPT fans is quite useless unless I can lower those tresholds 😄
