06-03-2014 03:08 AM - last edited on 03-05-2024 10:34 PM by ROGBot
06-03-2014 02:30 PM
06-03-2014 08:55 PM
06-04-2014 12:43 AM
06-05-2014 03:11 PM
A very good air cooler is required for voltage levels above 1.15V.
1.20V-1.23V requires use of closed loop water coolers.
At 1.24V-1.275V dual or triple radiator water cooling solutions are advised.
06-05-2014 05:10 PM
JackNaylorPE wrote:
Up to 1.200v = Very Good Air Cooler (Hyper 212)
Up to 1.250v = Best Air Coolers (Phanteks PH-TC14-PE, Silver Arrow or Noctua DH14) ....... Dual 140mm CLC / AIO Cooler w/ 1500 rpm fans (Corsair H110)
Up to 1.275v = Extreme Speed CLC / AIO w/ 2600 rpm fans (too noisy for most folks)
Up to 1.325v = Custom Loop w/ 15C Delta T (3 x 120mm / 140mm)
Up to 1.400 = Custom Loop w/ 10C Delta T (5 x 140mm or 6 x 120mm)
06-06-2014 09:16 AM
jab383 wrote:
My experience is that these are severe overkill. The real requirement is to keep the CPU core temperatures low.
"Define LOW."
For everyday 24/7 use: under 50C.
For an intense, demanding game for several hours: under 80C.
For a competitive benchmark: The CPU's throttling limit is 100C.
What does it take to get those? That depends on the power level, not the core voltage. I recommend Aida64 as a monitor that includes power as one of the measured values. Core voltage is moderately useful as a guess what power will be if a power measuring monitor is not used. It doesn't tell the whole story, though. Power is directly proportional to clock frequency at constant voltage.
My experience with 4770K in various cooling conditions:
1. Not delidded, MX-4 TIM (8.5 W/mK), Hyper 212 EVO air cooler
Handled 117 watts with less than 93C core temperature. That was x42 core multiplier and 1.27Vcore
Running OCCT small data set - a non AVX stability test that maintains a steady high power level. It also ran Aida64 FPU test - an AVX test.
The point here is that when clock rate is low, voltage can be high and be safe with an air cooler.
2. Not delidded, MX-4 TIM, custom water loop with 2x 140mm radiator
Load of 116 watts ran temperature to 79C
handled 137 watts with less than 93 C core temperature -- x45 multiplier and 1.32Vcore
The point here is that a water cooler gives more watts for an overclocker to play with, but not enough for most of us.
3. Not delidded, liquid metal TIM (82 W/mK), custom water loop with 2x 140mm radiator
Load of 115 watts ran temperature to 76C
handled 146 watts with 94C core temperature
I don't think this is enough improvement to warrant the trouble and risks of electrically conductive TIM, but it make the point that things other than radiator size and fan speed have a lot to do with cooling.
4. Delidded, liquid metal TIM under and over the lid, custom water loop with 2x 140mm radiator
Load of 115 watts ran temperature to 64C
Handles 182 watts with 84C core temperature: 4750MHz overclock with 1.55 Vcore is as high as I can get it to go
The point here is again that TIM is important and that delidding to be rid of Intel's thermal bottleneck is worth far more than a larger radiator.
Another repeated point is that volts are not watts.
The water temperature in my 2x 140mm loop reaches steady state at 10C above ambient when overclocking in the range of 180 watts, plus some from the VRMs. I think more than that one radiator is overkill for cooling just the CPU and VRM. Of course, more watts have to be added when cooling GPUs in addition.
Jeff
06-05-2014 06:31 PM
08-06-2014 04:07 PM
