08-08-2012 10:26 AM
08-08-2012 01:16 PM
08-08-2012 01:44 PM
Zka17 wrote:
Hey Picasso! Sorry for being late in this thread... working, you know... 🙂
But I see that two great gentlemen joined, so things can not go too wrong... :cool:
Before I managed to go Asus way, I was using Gigabyte mobos for a while... and had the chance to met EasyTune... - I can say only one thing about it: uninstall it as soon as you can! It's my personal opinion... but never had any luck with it... 😞
As previously was suggested, go from the BIOS... it's not too hard and it's fun! 🙂 I've used (still have somewhere) the 920 too - that should go 3.6-3.8GHz with a water cooling setup! At least mine was doing it (C stepping, the worst one) with a H100...
I will have to look for my notes to be more exact, but start with following HiVizMan's advice and read a little bit about OC'ing from BIOS...
Instead of ET, you could use HWMonitor for checking your temps... and download CPU-Z to see where your CPU and memory are...
The really first thing you have to do after uninstalling ET, is to go in BIOS and load defaults... then check the temps... - if they're still like now, you have to stop thinking about OC'ing until you fix the cooling...
08-08-2012 01:59 PM
