Help with oc M4A89GTD Pro UsB 3
ravfour22
Hey everyone, I have a M4A89GTD/pro/usb3, with 2X4 gig 1333 corsair xms3 with a 955 black C3, Looking for anyone with a good stable oc for this, any help would be greatfull.....
Thanks in advance
Nick
P.S. I have H70 cooling to...
Fx-8150, 4.5GHz, 1.34v. H70 Cooling, Corsair Dom 2 X 4Gig 1866MHz 9-10-9-27-2T-1.5V, Crosshair V, Hx850 PSU, XFX B.E. 7970 DD, 3 X 23 Led's, 2 X 1Tb Blacks, 2 X 2Tb Greens, 5Tb NAS Cloud, Logitech Mx Mouse, Logitech 7.1 surround,
Life is what you make it.
4 REPLIES 4
X-ROG
Level 15
With a 955 BE C3 you should easily get 4Gs on that. Just increase the voltage a bit and up the multiplier. The Pro has enough VRM power to cope.
Either that or use the TPU switch on the board or OC Tuner within the BIOS which will help OC for you.
Thanks for the reply, I thought I had it stable at 3.8GHz, then for some reason it came up oc'ing error on boot, not sure why.
The computer is not mine, just trying to do a friend a favor, so I don't have access to it all the time. My first cpu was 1100T Black so not really up on the 4 cores of that series...
Thanks again for reply
Nick
X-ROG
Level 15
Just bump the voltage up a touch from previous, or reset the OC from a BIOS Profile and go again - maybe it had a hiccup that one time?
Sounds good, will try..
Thanks for your help
Nick
