04-19-2012
05:56 AM
- last edited on
03-06-2024
09:14 PM
by
ROGBot
04-19-2012 08:05 PM
04-20-2012 12:08 AM
MarshallR@ASUS wrote:
With a 955 BE C3 you should easily get 4Gs on that. Just increase the voltage a bit and up the multiplier. The Pro has enough VRM power to cope.
Either that or use the TPU switch on the board or OC Tuner within the BIOS which will help OC for you.
04-20-2012 01:33 AM
Just bump the voltage up a touch from previous, or reset the OC from a BIOS Profile and go again - maybe it had a hiccup that one time?
