|| Help with OC 4470k + Hero VI + H100i ||
siliconart
Hey Nate152,
From your posts I have read, you seem to really know what you are doing.
I was wondering if you could help me OC my 4770k?
System Specs-
CPU- Intel Core i7 4770K
Motherboard- Asus MAXIMUS VI HERO
RAM- Gskill TridentX 16GB (2x8) DDR3 2400Mhz
GFX Card- Asus Geforce GTX780 DirectCU II OC 3G
SSD- Samsung 840 PRO SERIES 256GB
HDD- WD 2TB Caviar Black 7200rpm
CPU Cooler- Corsair Hydro Series H100i (Fans upgraded to: Air Series SP120 HP)
PSU- Corsair AX860 Platinum Power Supply
All Fans controlled by AiSuite
My time zone is +10GMT
Regards,
siliconart
- Intel Core i7 4770K OC @ 4.3 - MAXIMUS VII HERO - Gskill TridentX 16GB (2x8) DDR3 2400Mhz - 2x Asus Geforce GTX980ti DirectCU II OC 6G in SL I- Samsung 840 PRO SERIES 256GB - WD 4TB Caviar Black 7200rpm - Corsair Hydro Series H100i (Fans upgraded to: Air Series SP120 HP) - Corsair AX1200i Platinum Power Supply
167 REPLIES 167
siliconart
Oh great 🙂 will test BF4 now
Are you saying you can over stress the CPU too much even when its cooling fine?
Nate152
I'm just saying once you are stable there is no need to test for stability again is all. And yeah go kill some bad guys in battlefield 4 you can post your temps if you want.
siliconart
Here are the results
4.3GHz @ 1.36v
Running BF4
35549
ASUS GTX 780 Direct CU II
BF4 Ultra Maxed out with FRAPS FPS @ 1920x1080 120Hz
35550
Quick Pic of My PC
35551
Thank you again so much for your help, I now have a stable PC.
The last test will be when I Live stream BF4 on Twitch via Xsplit, I will monitor Temps then also.
r0wnin
If you're only running 4.3 I'm willing to bet you can be 100% stable under 1.29 vcore.
Personally, I would attempt it.
[Asus HERO - i7 4770k @4.3 - 32gb G.Skill Ares @2400 via XMP - Samsung 840 SSD - 660GTX in SLi]
Hello r0wnin, did you read a page or two back? He needed that much voltage to pass the realbench video encoding test.
I see your Specs seem to be very similar to mine. May I ask what your OC settings are?
All c-states and speedstep disabled.
Under the custom cpu power profile:
Load lvl 7
Extreme profiles.
130% cpu
130%mem
Nate152
Hey no problem , I'm sorry it took so many hours to get there. You're temps are fine and when overclocking always make it a habit to monitor your cpu temps. That's a nice gaming pc you have there and you have it nice and clean looking in there. Not a bunch of wires/cables hanging/dangling around. Sticking true to the ROG color theme tops it right off.
siliconart
Nate152
Do you happen to know anything about GFX Card OCing?
Nate152
Yes I overclock my gpu's using precision x. I like precision x because It has on screen display and can show your frames per second, gpu temp, gpu usage, gpu memory usage and more while playing games. I don't think GPU Tweak has on screen display.
