help with hard drives
Anthony911
hi,
I had a 320gb crappy hard drive and upgrade to a momentus xt gen2 750gb.
I used a program called AOMIE partition assistant to copy everything form hard drive to hard drive,
I went in the bios and tried to boot off momentus, but the message bootmgr press ctrl+alt+del to restart ( I think is was that ) come up, so I went into disk management, but cant seem to make e: ( which is momentus ) to c: or make e: bootable but no luck there.
Can anyone help??? PLEASE
10 REPLIES 10
Anthony911
should I just format the momentus and install win 8 which is a pain cause I have to go to a mates house n use his cd or is there a quick easy way to make the momentus bootable or make it c:
HiVizMan
Level 40
Please provide a touch more information.
List your hardware and the OS of the 320GB drive.
Anthony911
I have a maximus v formula, 2x4gb g skill 2400mhz ram, intel i7 3770k, asus gtx 660 duc2, cd drive is a dvd multi layer burner
os on 320gb drive windows 8 pro
HiVizMan
Level 40
Macrium Reflect Free is what I used. Once the drive was cloned I removed the other hard drive completely from the system. Went into BIOS and F5 and enter to set defaults.
Posted to OS as easy as that.
Anthony911
so I should format the hard drive and use macrium reflect free
Actually this tool may suite your needs better.
http://www.majorgeeks.com/files/details/minitool_partition_wizard_home_edition.html
http://www.partitionwizard.com/
HiVizMan
Level 40
What are you formatting your new dive too?
Anthony911
just the new one
Anthony911
I tried those 2 but they didn't work.
Macrium Reflect Free work 😃
thanks heaps
another quick question I have 2x4gb g skill ram sticks code f3-2400c10d-8gtx my asus book doesn't have them in it and my bios runs them at 1600 but using X.E.M.P (I think is was) in the bios I managed to get them to 2400mhz is that safe considering they weren't in the asus instruction booklet??
