HELP with Asus Suite
caponeel
I have a Z97-A and i dont have ratio and blck option on 5 way optimisation. Why? I have TPU switch on level 2. I need turn on someting else?
8 REPLIES 8
Chino wrote:
Please list your complete system specifications for me.
Asus Z97-A - Intel I7 4790 3.6 - Asus GTX 770 DC2OC 2GB DDR5 - 8gb Kingston Hiperx genesis 1600 mhz - westerndigital 2TB SATA - PSU 600w coolermaster - Coolermaster Storm Trooper Tower
Chino
Level 15
Chino wrote:
The i7-4790 is a locked processor. So you cannot change the multiplier.
Can do any safe overclock with this processor? I'm new in overclock world and only want to do a overclock on Suit 3. I'm afraid to enable and disable options on bios.
Sorry for my english, and tanks a lot for your reply 🙂
Chino
Level 15
The most you can do is move the BCLK a little. You can do the in the BIOS not sure if you can do that in AI Suite III though. I've never worked with a locked CPU.
I'm at work, tonight i will try move the BLCK. If move BLCK a little, i've increase the voltage to?
Chino wrote:
If you leave it at Auto it will increase itself.
Hi Chino.
I tried de auto OC on Asus Suit. Auto change the frequency to 105.00 and left the max ratio on 40. I ran a prime95 stress test for 30 min and got a 68c 66c 64c 68c Temp. I think the voltages are goods to 4200mhz OC. I will try buy a K processor and a watercolling system.
Thanks a lot for your help 🙂
