help with 24\7 overclocking 13900k
tomerturbo
hello everyone my setup
ROG MAXIMUS Z690 HERO
i9 13900k
2x16gb g skil 6400mhz
cpu cooler nh-d15
my setings is p-core 55 e-core 45 ring 50
my idle voltage is between 1.28-1.305 in game my voltage is between 1.25-1.22
my temps in games is 70-77c
in cinbench r23 my max temp is 88c the cpu puts 250w
does it safe for 24\7 does my temps and voltage are safe for 24\7
thanks for the help
Silent_Scone
Super Moderator
Hello,
Yes these settings are fine. Are you setting a manual voltage? For best results on this platform you can check AI OC petametres within the AI Tweaker menu.
Silent Scone@ROG wrote:
Hello,
i use auto voltage DC_LL = 1.02 AC_LL=0.12 LLC4
This is fine
