11-24-2019
06:06 AM
- last edited on
03-06-2024
07:22 PM
by
ROGBot
11-24-2019 07:06 AM
11-24-2019 07:11 AM
Arne Saknussemm wrote:
From what I've seen of these CPUs...real stability at 5.2GHz takes more than 1.3v on average.
11-24-2019 07:23 AM
11-24-2019 07:39 AM
That's all core stability so you may run less for individual core OCs.
I've used CPUz and HWiNFO...for software readings...for what they are worth. RealBench is a good whole system stress test. If you pass an hour on that you're good to go for pretty much anything.
11-24-2019 08:14 AM
11-24-2019 09:10 AM
These CPUs are very Vcore dependent yes.[/url]
11-24-2019 09:35 AM
11-24-2019 09:55 AM
Are you setting manual voltage...or adaptive? And what power plan settings...
Any avx offset....latest Realbench and prime run avx and will pull a lot to run at high ghz.
11-25-2019 07:23 AM
Alexauwa wrote:
I run 1.30 vcore fix (manual) at the moment. Power plan (you mean under windows?) is set to high power on all settings. Avx = 0.
Realbench hits the 1.42 on VID. But VID it not the vcore right?
To get this right... VID is the vcore with LLC kicked in. Giving me a total vcore load of for example 1.42 in real bench. But when not using benchmark and stress test in real bench instead, I get immediate crash. In order to have vcore and VID match, I set the LLC corret. In my case this is 6 (turbo on gigabyte). But having a vcore in bios set to 1.3 and a VID of 1.42 is big jump right? So I shall set my Vcore even higher to maybe 1.35?
