HELP RAM TIMING 3000MHz
pegadroid
i7 6700k 4.6GHz 1.350V
ASUS Z170 DELUXE
32GB 4X8GB CMR32GX4M4C3466C16 run with 3000MHz 1.300v 15-16-16-39 2T run Stressapp test for 1 hour with no error
this timing too loose?
34 REPLIES 34
Nate152 wrote:
That sounds ok as long as IO and SA voltages aren't too high, otherwise you'll have to loosen timings until you find stability.
I asked at the Corsair forum, they suggest run at 3200 14-14-14-34 1.35V, I was very difficult to boot before at 3200 16-18-18-36. i try run 3200 14-14-14-34 1.35V, i can boots , but when run hci after 9% i have one error,
Try 14-15-15-36 at 3200.
200% pass hci at 15-15-15-35 2T, which better 14-15-15-36 or 15-15-15-35 ?
Nate152
Nate152 wrote:
14-15-15-36 would be the best timings.
run hci and getting error at 4%
I tried running with 2 pieces and successfully running xmp 3466
I am very confused, my Asus Z170 deluxe is bad?
