[HELP] Overclocking 9900K on Maximus X Hero
TheTiesThatBind
So I’m trying to OC my 9900K on Maximus X Hero but I face some difficulties. Even though I manage to pass Intel Burn Test with 10 Loop at Very High with 1.24V @ 5GHz I’m getting BSODs on RealBench. Any ideas why/what should I try next?
I just put 50 on the multiplier, 1.24V Manual volt and lift any power limit. And of course enabled XMP and Disabled C-States*
TheTiesThatBind
So as of I now I’m still not able to pass RealBench at 1.24, 1.26V Stress Test but I’m able to pass IBT.
I tried 1.29 and 1.28 Volt and had no trouble passing RealBench but VRM Temp sensor in HWINFO64 peaked at 101C.
I also tried 4.9 @ 1.24V both tests passed and also I had both tests successfully passed with 4.9 @ 1.20V so far.
I will try even lower see where it lands. But why I pass IBT @ 1.24 and getting BSODs at RealBench in the first few seconds at 5G @ 1.24V?*
IBT basically stresses the CPU and not much else.
RB is more realistic in that it stresses the entire system: CPU, graphic card, and memory.
Intel i9 10850K@ 5.3GHz
ASUS ROG Strix Z490-E
Corsair H115i Pro XT
G.Skill TridentZ@ 3600MHz CL14 2x16GB
EVGA RTX 3090 Ti FWT3 Ultra
OS: WD Black SN850 1TB NVMe M.2
Storage: WD Blue SN550 2TB NVMe M.2
EVGA SuperNova 1200 P2
ASUS ROG Strix Helios GX601
HisEvilness
Ensure you test with none AVX loads as well, and make use of an AVX offset for the tasks that would need it. Gaming etc does not need AVX thus you can get higher clocks for that vs rendering that does need AVX.
