Help on video card issue
yeLLoW
hello, i am seeking for help in order to fix my computer, i had left my computer on sleep and when i went to wake it up it froze, i restarted and got a BSOD with an 0x116 error, i have a nvidia geforce 660 , i reinstalled the drivers to a previous version on safe mode and it got fixed, when i restarted another BSOD came up with a 0x7e error. it said i had to switch video adaptors. i checked for viruses, updated drivers but nothing seemed to work so i reinstalled windows 7 . now when i turn on the computer it doesnt recognize the monitor or the video card. i tried reinstalling the drivers for the video card with no result. could it be that the video card is broken? i took it out and checked for any damage but it had none.ive only had this computer built a year and 3 months, and it was working good, except that when i play cs go it would restart my game constantly, and randomly. i think the video card should last a bit longer, any suggestions? here are my specs:
Asus M5A97 LE R2.0
8gb DDR
amd fx 8320
nvidia geforce 660
thanks for your help
7 REPLIES 7
abvolt
Level 11
I would start by setting up an rma for your 660 sounds like a bad vga to me, who's the maker of your card ?
Current: MSI Xpower Gaming Titanium | 7700K | G Skill Ripjaws V 3000 16Gb | 960 EVO 500Gb | Intel 730 480Gb | Seasonic 1000 Platinum |
NZXT X62 | Acer XB270HU | EVGA 1080 ti FTW3
Secondary: R4BE | 4930K | G.SKILL 2400 16GB | Corsair AX 1500i
Intel 730 240GB + 480GB | EVGA GTX780 ti sli kpe | Custom H20
the videocard? evga nvidia
DekonX
Check the ram. It might sound dumb but im betting a stick of ram is the problem. Get memtest and run it 1 stick at a time. This will require a few reboots. However this may be your problem. I had a similar problem and had to RMA my ram about a year ago. It drove me up a wall trying to figure out why my system was randomly crashing and rebooting only to find out that a stick of ram died on me.
AMD 9590 (4.7ghz)
CROSSHAIR V FORMULA-Z
12Gig DDR3 1333
XFX R9 280x
Corsair RM850
Nanoxia Deep Silence 6
i see,okay im going to do that, also my ethernet adapter is not recognized so idk how id get memtest, my desktop has a wireless adapter, no lan outlet. could that be associated with the ram problem too?
HiVizMan
Level 40
0x7e error is most commonly a memory error.
You can follow the Memtest86+ guide in my link. That will show you how to run the test.
yeLLoW
okay here is an update for this problem, i fixed the network adapter driver problem. i also ran the computer with each memory stick and still had the problem, now im going to run that memtest86 and see how it goes!
yeLLoW
as recommended on the link, i ran 2 cycles and both passed, i also ran chkdsk and found no errors.could it be the graphic card is bad? i dont have another desktop to try it on, but i guess im going to have to try with another card and then return it if anything
