Help OC..
DeathGod
Hello i just need help or advice Ocing my RIG on stable 24/7 coz i this the firts time for me so i need some guide and advice
for the best OC.Thanks
My RIG:
Intel i7 3770k
MB: Asus Maximus Formula V
PSU:Corsair GS 700 Gaming Series
SSD:Samsung 128GB 830 series
VC:Asus GTX 560 1GB ram
RAM: Corsair Vegeance 1866mhz 8GB.
Cooling: Corsair H100
||Mobo||Asus Maximus Formula V||CPU||i7-3770k||Ram||Corsair Vegeance 8GB 1866mhz||
||GPU||Asus GTX 560 1GB DDR5||SSD||Samsung 830 Series||Cooling||Corsair H100||PSU||Corsair 700w Gaming
12 REPLIES 12
Krindor
Level 11
Is it the Maximus V Extreme or the Maximus V Fomula?
At its simplest all you need to do to overclock is to change the AI overclock tuner to XMP, or Manual if your RAM doesn't use XMP.
After that change the value of BCLK to 100, if it isn't already that. Then Increase the multiplier to a wanted amount. As you increased the multiplier the CPU will need more power so you'll need to balance that out by increasing CPU voltage. After every OC go into windows and run HWmonitor and Prime 95 to see if it's stable and to check temps. Try to keep load temps at 70-75C for a 24/7 OC.
| Chassi: Phantom Fulltower White Edition | Mobo: Maximus V Extreme | CPU: i7 3770k
| Memory: 2x8gb G.Skill Trident X 2400mhz | GPU: PNY Geforce GTX 670 | PSU: NZXT Hale 90 750w
| SSD: Intel 120gb 330 series (OS) | Intel 120gb 330 series (Games n stuff)
| Monitor: LG 29EA93 | Cooling: Custom Loop
Sorry was wrong i corrected now. thanks
Thanks Guys now ill try to read before ocing.
Arne_Saknussemm
Level 40
Hey DeathGod 🙂
Have you seen this thread...http://rog.asus.com/forum/showthread.php?19186-ASUS-ROG-Maximus-V-Formula-UEFI-OC-Tuning-Guide&count... from the Maximus section. It is a good guide for OCing..have a read and get back to us!....
And read this for a super simple OC...http://rog.asus.com/forum/showthread.php?5836-ASUS-Rampage-IV-Extreme-Easy-Overclock-Guide&country=&...
This is for a different board but the principle is the same....
Thanks for the fast reply i will read. 🙂
but this guide is for all ROG MB?
Krindor
Level 11
For the latest CPUs and with the UEFI bios it's about the same for all mobos.
HiVizMan
Level 40
There is one key "rule" when over clocking.
Let temperatures be your guide.
All else is secondary.
Hi its ok ocing in Ai Suite ll? its advisible or much better manually? thanks
Arne_Saknussemm
Level 40
