05-05-2012 10:06 AM - last edited on 03-06-2024 09:02 PM by ROGBot
05-05-2012 10:11 AM
05-05-2012 10:12 AM
05-05-2012 11:29 AM
05-05-2012 11:40 AM
PC Specs: Intel 2500k - 4.6GHZ (Overclocked) 7 Stepping CPU.
Corsair Vengance 16GB 4GB Kit @ 1600MHZ 9/9/9/24/2 - now overclocked: 1866 9/10/9/27/2- ATI 6850 GFX - (OC 855mhz/1165) -
Maximus Gene Z/Gen 3 3305 BIOS, Voltages: Ram 1.6 - CPU 1.360 / 75% Vdroop. VCCISO 1.1500.
Antec 300 Case - Sata II 5400 RPM 500GB Master HDD.
05-05-2012 11:45 AM
Moloch wrote:
Your timings look ok to me. It's probably your voltage causing problems. Your ram is only rated for 2133, it may or may not OC to 2400 even with extreme voltages.
I'm running some Corsair ram, rated at 2133 @ 1.5v, at 2333 @ 1.65v. That's as fast as I was able to push it. I think it can do 2400 at around 1.7v, but I'd rather not go that high myself.
I've seen G.Skill ram rated for 2133 @ 1.65v rather than the 2133 @ 1.5v like my ram. If yours is rated 2133 @ 1.65, you might not be able to get it any higher. If it's 2133 @ 1.5v, you might be able to do 2400 if you want to push it to the 1.65-1.7v range.
Keep in mind you will want to raise your VTTDDR in step with your DDR voltage. It should be around half, default being 0.750v with 1.5v ram. At 1.65 you would want the VTTDDR at 0.825v.
05-05-2012 12:10 PM
05-05-2012 12:03 PM
05-05-2012 12:11 PM
tistou77 wrote:
My OC is stable (OCCT, HyperPI 32M and current use)
I just wonder if there are settings to refine
CPU Current Capability, etc....
Thanks 🙂
05-05-2012 12:36 PM
