I'm building a new rig, and just assembled the parts yesterday. I have everything connected and I turn my rig on, all fans work perfectly, LEDs come on, optical and hard drives start spinning.
There are however a couple of problems, and I would want to know if they're linked or if they are two separate ones. Firstly, my DVI-out does not work, three monitors could not detect any signal. Secondly, the USB 2.0 ports on my motherboard do not work at all. Is this primarily a motherboard or GPU problem?
Specs:
Asus Formula VI RoG motherboard
Asus R9290-4GD5 GPU (AMD R9 290x)
Corsair RM850 PSU
4x4 GB G.Skill RAM
I tried cycling the RAM, and I unplugged my 8 and 6 pin PCI-E connectors from the GPU and reconnected them. Don't know what else to do really, can't access BIOS and since this is my first build in the US I don't have access to an old system I can scrounge parts off of.
