help me to choose ram kit for R4BE............
fm_sam_bahadur
i was thinking to go with this ....
http://www.gskill.com/en/product/f3-17000cl11q-16gbzl
i have check on R4BE Memory QVL this ram kit is not there......i already ordered this ram kit ..... i dont know what should i do plz help???????
Zka17
Level 16
If you check the QVL on the GSkill site, you will see that the kit is recommended for the RIVE - so, it should work with the RIVBE too...
