Help me reach 5GHz+ on my de-lided 8700k
MR_G
I followed Nate152's instructions for someone else(https://rog.asus.com/forum/showthread.php?100733-My-first-overlcock-i7-8700k) and was able to get to 4.9 stable but occasionally BSOD's at 5GHz. I just de-lided my proc with RockitCool's kit and their copper IHS. I have not tried overclocking since I did the de-lid 2 days ago.
Here are my specs
Phanteks Enthoo EVOLV MATX TG
Asus ROG Strix Z370-G Gaming AC
i7 8700k @ 4.9GHz (de-lided with RockitCool' copper IHS and Coollaboratory Liquid Pro) idles under 100F
Corsair H115i (pump on extreme and fans on quiet)
32GB G.Skill Trident Z 3200 14-14-14-34 (samsung modules)
Asus ROG Strix GTX 1070 8GB
Samsung 960 EVO NVMe M.2 500GB
Corsair RM750X Gold
Windows 10 Pro x64
I have HWInfo64 and RealBench installed.
Here is a screenshot of HWI after running RealBench de-lided @ 4.9GHz
73388
Here are pics of my BIOS changes to get to 4.9
73389
73390
73391
73392
73393
I hope I have provided all of the information to get me rolling. Looking forward to hearing from Nate152 😃
Phanteks Enthoo Evolv X
ASUS ROG Maximus XI Hero (Wi-Fi)
i9 9900k @ 5.1GHz
Corsair H115i Platinum RGB
32GB G.Skill Trident Z 3200 14-14-14-34-2T (Samsung B-Die)
Asus ROG Strix RTX 2070 OC 8GB @ 2055
Samsung 970 PRO 512GB
Samsung 970 EVO Plus 500GB
Corsair RM850X
Windows 10 Pro x64
11 REPLIES 11
Nate152
Hi matt
Looks good !
Set SVID Behavior to Best Case Scenario.
Set the cpu core ratio limit to 50.
Enter in 1.350v in the "additional turbo mode cpu core voltage override."
F10 and Enter to save and exit, run Realbench to see if you pass the test. Post a screenshot when the test has finished.
Hwinfo is showing a bunch of settings not being monitored, have you changed anything? Here is how it should look, what I have circled is the cpu speed, cpu voltage and and cpu temps.
Click the pic to make it bigger
73396
MR_G
Coming right up 😃
i9 9900k @ 5.1GHz
Corsair RM850X
Windows 10 Pro x64
MR_G
RB ran without a crash and I ran Prime95 for 10 min with no errors (P95 was erroring out @ 5GHz before the de-lid). Temps are awesome too!
73397
73398
i9 9900k @ 5.1GHz
Corsair RM850X
Windows 10 Pro x64
Nate152
The image editing score is a bit low, the time should be down closer to 20 seconds.
Try rebooting and run the test again and see if the image editing score is any better. If it's not any better, you may need a little more Vcore for a proper score.
How much more Vcore?
i9 9900k @ 5.1GHz
Corsair RM850X
Windows 10 Pro x64
MR_G
Doing it now...
i9 9900k @ 5.1GHz
Corsair RM850X
Windows 10 Pro x64
MR_G
73402
73403
i9 9900k @ 5.1GHz
Corsair RM850X
Windows 10 Pro x64
Nate152
All right, I think the image editing score could be alot better, try raising the Vcore .01v to 1.360v and try the test, if it's the same try 1.370v and up to 1.40v if needed.
Here is my realbench score, see the image editing score at close to 20 seconds.
73405
MR_G
Ok, I think I have settled on 5GHz @ 1.390. 1.400 was a tab hotter and only a couple of points higher compared to 1.390. I tired 5.2GHz @ 1.400 and it BSOD'd halfway through a RB benchmark. I am chalking up your better scores to being oc'd to 5.2 and having a Titan XP video card 😃 DO you think oc'ing my 1070 would make much of a difference?
1.400 RealBench
73406
1.390 RealBench and HWi
73407
73408
i9 9900k @ 5.1GHz
Corsair RM850X
Windows 10 Pro x64
