Help me choose
NickForcer
I decided to take asus maximus v formula but i accidentally ordered intel core i7 3770k instead of 3770k 😞 will i be able to overclock to 4 ghz and higher or i have to change it with k will i see an differences
HiVizMan
Level 40
I think you mean you ordered a 3770 instead of a 3770K.
Pretty sure you can get close to that in not higher. Your turbo multipliers go up to 39 right. And if you increase your BCLK you will get to 4GHz I am sure.
Yes i mean 2770 instead of 2770k
Thanks for the answer but i now send it back to the store.
