Hello there folks i hope someone can help me with this :
when i set my cpu ratio setting to > * By Specific core * on cpu ratio setting in bios i face 2 big and weird problems :
first one is that i want one of the cores (in my case its core#2) which is my hottest core to be set to Lower ratio so i can push lower voltage on it so it will cool down but ANYTHING i set blow 1.2v for it even on 3.0 ratio is unstable even when i set its Ratio to 30 and give it voltages like 1.1v to 1.16v (which are stable voltages for even 4.4ghz on my cpu when i use Sync all cores option) WHAT IS HAPPENING HERE?:O
another problem i have here is that i have set for example 4 of the cores to 4.7 and the rest of the cores to 4.6 BUT in windows when i run any test or any program all cores boost to 4.7 on loads but i only want 4 of them to work on 4.7 not all of them whats the heck is all these weird issues that I HAVE NEVER SEEN BEFORE OR HEARD OF ?
is all of these bios bug or something else?
my system specs are in my sig and user spec info
look at this shot from hwinfo64
EXTRA INFOS: currently i have disabled the hottest core (Core#2) in bios and its working on 7cores instead of 8cores for now
my current bios is 1503 and the voltages and ratios that im talking about have been tested and been used for 1+ year and are stable settings when i use SYNC ALL CORES
just this *specific Core* option is the only mess and problem here
UPDATE:
Enabled C-STATE in bios to get it working on per core overclock
_______i7 7820X
________RAMPAGE VI APEX
_________G.SKILL 4x8 @3733 16
__________MSI 1080ti LIGHTNING Z ||O'\\\\'O'////'O_|
___________Intel 750 PCIE SSD
____________Corsair AX1500i
_____________Corsair Obsidian 900D
_______________Corsair H150i Pro 360 AIO
