Help For Overclock. (Rampage 2 Extreme i7 975Mhz)
cintiq
Many times I stepped up to this time overclocking, but overclocking would learn to make the document could not get a good overclock my computer and now I want to see the maximum potential. I would be glad to support me you can be on this issue.
www.emreozsoz.com
CPU : Intel i7 975Mhz Extreme
MB : Rampage II Extreme
Mem : Corsair Dominator GT 6GB, 7-7-7-20
GPU : Sapphire HD5870 1GB
PSU : High Power 1000W
OS : W 7 x64 Ultimate
Mouse : Cyborg R.A.T 7
CPU Cooler : Corsair H100 Water cool
Case : Zalman GS1000
4 REPLIES 4
HiVizMan
Level 40
There are 1000's of guides all over the web on how to overclock a X58 set up.
Set your multi to 20
Set your BCLK to 200
Set your Vcore to 1.4
F10 and enter
Your system is booting at 4GHz
actually saying that I could not find what I mean, I could not find a guide explaining the logic of overclocking. for example, such as voltage according to what needs to raise. the evening will make adjustments with the values ​​that you have provided.
www.emreozsoz.com
HiVizMan
Level 40
Well if you could not find one then maybe I misunderstand what it is you are looking for 🙂
Go read here it will get you started.
http://www.clunk.org.uk/forums/overclocking/22106-core-i7-overclocking-guide-beginners.html
Wow I think this is quite a shine to me. The evening will be the first thing I read this article :). It is better if you fully understand it and start sorna overclocked.
www.emreozsoz.com
