05-28-2013
06:32 PM
- last edited on
03-06-2024
09:02 PM
by
ROGBot
05-29-2013 01:33 AM
05-29-2013 07:03 AM
PlaneName wrote:
Ah I remember having this issue with an older laptop. Do you have a yellow exclamation mark icon in device manger? it will tell you what issue code you have before we go further. Here are the codes:
http://pcsupport.about.com/od/fixtheproblem/tp/device_manager_error_codes.htm
This is the solution to fix the UpperFilters and LowerFilters Registry Values on the CD\DVD drive.
http://pcsupport.about.com/od/driverssupport/ht/upperfilters-lowerfilters.htm
Will wait for your response.
Edit: I Just read the old thread you have inserted and you positively sure that you have done this step properly? It might be a windows update or drivers fail, go to system restore and go back where your laptop was stable. I just researched that iTunes can also cause this problem try uninstalling iTunes if you have it.
05-30-2013 03:01 AM
