Had a problem with my mobo yesterday, need advice
Cabelo
about 3 day ago i clocked my coirsair domintor GT to 2133 as someone teach in someplace in this forum that i don't remember where, my PC i working pristine apart from random crashes in dota 2 and a GPU driver crash that happened after the clock (didn't happen again after a patch release in the other day). I tested the new Tomb Raider and Hitman Absolution with everything on max and nothing wrong happened. Yesterday i was watching The International 3 and a notice box appeared in the corner saying something about a voltage problem (it close itself before i could read it...). Next thing i noticed it was the mobo sensor was displaying
what i marked on the screenshot as red and with "0 V" oppose to this numbers that now displays. The PC was still working fine
and i watched the tournament till the end and turned off the PC, so it crashed. i didn't care at the moment. This morning i turned
on and nothing happened. next to that i tryed to remove the memory 1 by 1 and start the PC, the result was the same even
without any memory then i noticed the CPU led was on, then i holded the start button on the mobo to try this soft mode (manual) with only 1 memram on it, still nothing, put the other 3 mem on it again and tryed again with this soft mode, nothing. Just tryed to turn the PC on again and for some unknow reason it worked normally. The PC still on 2133 and working fine, any hint?24709
sorry if my english is horrible, did the best i could, hope that's understandable
6 REPLIES 6
Myk_SilentShado
Level 15
Uninstall AISuite II and save yourself a lot of hassle, then download something like HWMonitor to monitor your Temps and Voltages 🙂
Also, you may need to increase your DRAM Voltage a little to return stability back to your machine 🙂
i know hardware enough to make this machine myself but i have no idea how to work with voltage =(
Cabelo
Proc - FX 8150
Corsair domintor GT 2133
Radeon 7970 3GB sapphire
kkn
Level 14
look in the crosshair forum tread.
go in to bios and up the voltage on the memory.
best is to OC inside bios ( even as the AI suite alows you to OC in OS )
http://rog.asus.com/forum/forumdisplay.php?117-Crosshair-Series-Motherboards
why should i delete it??????? i have been always there as long as i know
Arne_Saknussemm
Level 40
How did you get your ram to run at 2133....did you use the DOCP profile in the BIOS?
I too would suggest un-installing AI suite and then after the normal removal....run this file to completely remove it from the registry etc.
http://rog.asus.com/forum/showthread.php?28319-AI-Suite-II-uninstall-cleaner
