General PC temps
GonzJ
Hey guys,
This is my PC spec:
Case- CORSAIR GRAPHITE SERIES™ 600T WHITE MID-TOWER CASE
Processor (CPU)- Intel® Core™i7 Six Core Processor Extreme i7-4960X (3.6GHz) 15MB Cache
Motherboard- ASUS® RAMPAGE IV BLACK EDITION: INTEL X79, SOCKET 2011, R.O.G
Memory (RAM)- 16GB KINGSTON HYPER-X FURY DUAL-DDR3 1600MHz, X.M.P (2 x 8GB)
Graphics Card- 3GB NVIDIA GEFORCE GTX 780 Ti - 2 DVI, HDMI, DP - 3D Vision Ready
2nd Graphics Card- 3GB NVIDIA GEFORCE GTX 780 Ti - 2 DVI, HDMI, DP - 3D Vision Ready
1st Hard Disk- 1TB Samsung 840 EVO SSD, SATA 6Gb/s (upto 540MB/sR | 520MB/sW)
2nd Hard Disk- 4TB WD CAVIAR BLACK WD4003FZEX, SATA 6 Gb/s, 64MB CACHE (7200rpm)
Power Supply- CORSAIR 1200W PRO SERIES™ PLATINUM AX1200i DIGITAL MODULAR PSU
Processor Cooling- Corsair H100i Hydro Series High Performance CPU Cooler
I am a little worried about the temperature of my PC. When sitting idle, everything is within 2-3 degrees C of 30. Which I am fine with. But often when in game my CPU reaches around 60 and my graphics card is around the 65-70. I know this is well within the limits of my components, however this is in older games. When playing watch dogs earlier my CPU hit 75 degrees C, and my cpu reached 65 degrees on sleeping dogs.
I have tried bumping up the speeds of fans, but then my PC becomes excessively loud, so loud in fact that I can hear it through my headphones and other people in the house can hear it, even downstairs.
Do you think I am worrying unnecessarily? Are these temps fine?
Thanks for reading guys!
PS. I am not overclocked at the moment, this is mainly down to the temps I am seeing.
5 REPLIES 5
GonzJ
Also if i was going to overclock, what speed and volts would you recommend? I have no idea how to go about overclocking either 😕
HiVizMan
Level 40
How have you fitted the fans on your CPU cooler? Maybe have them pushing or pulling cool air into the case.
GonzJ
Front fan is pulling air in and back is pushing out.
HiVizMan
Level 40
So much for a quick fix then.
A couple of guys have said that they had issues with the seating of the CPU cooler (H100i) they had to put small washers at the back of the mounting plate to get more downward pressure. Wonder if that is the case with yours.
GonzJ
Hmm, how would I find out if thats the issue? Do you think that the temps are too high?
