front base vs OC panel
supermotolew
hi all im looking at fan controller solutions atm my rampage iv black came with the OC panel wich is nice but for 99% of the time I use it to view cpu temp and jump between OC profiles I cant seem to control my fan profiles with it .
the front base looks awesome and looks more like a fan controller and looks good value
what's the advantages and disadvantages of each ? can I only run 1 im guessing front base requires that connection from my OC panel to work?
thoughts ? any one tried both ?
kkn
Level 14
you cant use both TBH since they both use the onboard connector on the mobo.
i dont use the frontbase my self so i cant say for shure.
take a look at this link and see or mabye do a google.
http://www.asus.com/Motherboards/ROG_Front_Base/
