Fresh Strix 1070 - Nvidia control panel settings?
Jhesian
Just bought a gtx 1070 strix.
What are the first things i should change in the nvidia control panel settings?
I am using this for AAA gaming on a 3440x1440 ultrawide 60hz screen and i want to maximize quality but keep FPS above 30-40 minimum.
Are there any global settings to change? Should it be app specific?
Should i leave the nvidia control panel settings default and change settings elsewhere?
Thank you
Nate152
Hi Jhesian
In the 3d settings I set ambient occlusion to quality, texture filtering to high quality and maximum pre rendered frames to 2. Pretty much everything else you can set to application controlled and use the game settings, set all game settings to ultra with all Antialiasing settings turned off.
You can add more color and contrast under "adjust desktop color" below manage 3d settings.
It should look good and you should be above 40 FPS minimum. You could overclock it for a nice performance boost, there is a guide in my signature at the bottom of my post.
