Fixing Haswell and Ivy Bridge CPU temps
abvolt
Level 11
I ran across this video on youtube and was wondering if any of you guys used this fix. I have the sandy bridge-e cpu i7 all cores read different temps, example I'll run InterBurn test at high core 0 reads-78c core 1-59 core 2-71 core 3-67 core 4-62 core 5-72. Is this variation in cpu core temps normal.
Current: MSI Xpower Gaming Titanium | 7700K | G Skill Ripjaws V 3000 16Gb | 960 EVO 500Gb | Intel 730 480Gb | Seasonic 1000 Platinum |
NZXT X62 | Acer XB270HU | EVGA 1080 ti FTW3
Secondary: R4BE | 4930K | G.SKILL 2400 16GB | Corsair AX 1500i
Intel 730 240GB + 480GB | EVGA GTX780 ti sli kpe | Custom H20
4 REPLIES 4
HiVizMan
Level 40
I would not delid a IVY-E
I have core 3 a good 12'c than my other cores.
John_Smith
You won't be able to delid your Sandy as the top plate is soldered on. The Ivy's (and Haswell's I guess) have some sort of cheap rubber glue that holds the top plate on instead, which would allow someone to delid them.
I'm surprised that you are having temp troubles with a Sandy, those CPU's should be pretty sturdy temp wise. Ivy's on the other hand have cheap thermal paste underneath the lid which is why people are deliding them and reapplying high quality paste to them. Some are even running cooling blocks on the delided CPU! Risky but cool if you manage to not break it lol.
Google, Ivy delid hammer and vice...seems to be safer then the razor blade method.
EnthusiastBuild
Level 12
I was reading and watching youtube videos on the delid hammer and vice method for quiet some time now. My personal conclusion is, i won't do it, although the temparature fall is super nice. I wouldn't say I am not a handy person, but too much risk involved to actually ruin my 330 Dollar processor. My temps @4.5Ghz @1.35v - 75° max peak at RB2 100% load are not bad either for my H100i.
Aswell I think the fail rate of deliding is way higher than you read about in the interwebs. Of course, I mean who would post that they just ruined their processor deliding it, I would not either since i would be pretty ashamed lol.
If you want to do it, go for the hammer and vice method!
Cheers
CORSAIR 900D
ASUS MAXIMUS VI FORMULA
INTEL I7 4770K @ 4.5 GHZ
CORSAIR DOMINATOR PLATINUM 16GB @ 2400MHZ
SLI EVGA GTX 780 SC ACX
SSD SYSTEM: CORSAIR FORCE GT 120GB
SSD APPS: CORSAIR FORCE GT 240 GB
HDD STORAGE: WD BLACK 2TB
CORSAIR AX860I PSU
CORSAIR H100I 4 x SP120 HP
Holdt
I've delidded my i7-3770k with a hammer and a vice. Dropped 10 degrees celcius, and now running 4.5 GHz on air, Prime-temperatures at 70 max.
