10-15-2018
06:07 PM
- last edited on
03-06-2024
07:36 PM
by
ROGBot
10-16-2018 09:44 AM
10-16-2018 02:07 PM
Nate152 wrote:
Hello jelooknight
Welcome to the ROG forum !
I suspect your problem is with your ram, g.skill flare x is designed for ryzen platforms but it still may work.
Try setting your ram manually with Dram voltage 1.40v.
Raise both the cpu vccio voltage and cpu system agent voltage to 1.15v - 1.25v, start with both at 1.15v.
Does this get you stable ?
10-16-2018 02:17 PM
10-16-2018 03:25 PM
Nate152 wrote:
If it's still freezing, try loosening the primary timings to 15-15-15-35 with a command rate of 2N.
Also try reinstalling Realbench.
10-16-2018 06:52 PM
12-02-2018 04:53 PM
12-05-2018 11:03 AM
12-05-2018 11:20 AM
feedmeink wrote:
This might not be related to ram. Have you changed any main settings in bios related to cpu? You say this is your first OC. Typically you want to OC your cpu first, then once it is stable, work on ram. Have you done anything with the CPU in bios?
12-06-2018 06:03 AM
