Fans forced to 100% when CPU reaches 75C
TamiyaGuy
Been using a PRIME Z270-A, along with an i7 7700K, for a little while and I've got to say that as my first Asus product, I'm pretty disappointed. I've noticed that in both BIOS and AI Suite III fan control options, the fans attached to the motherboard force themselves to 100% speed when the CPU reaches 75 degrees Centigrade, and there doesn't seem to be any way to fix this. Having bought Asus specifically for their reputation in fan control options, and seeing other options like the "Extreme Quiet" PWM option and fan spin-up/spin-down time variation, this seems like a really strange limitation for two reasons:
1) Competitors seem to offer much broader temperature control. MSI allows at least 85C, Asrock seems to allow 90C, and Gigabyte allows full control up to 100C. So why is Asus so behind the competition in this, especially in this day of both silent systems and easy overclocking?
2) Intel themselves have said that a 7700K reaching 75 - 80C is "considered expected and normal". So why is Asus ramping up every fan in my system to 100% as if it's some kind of critical temperature?
Is there any way to bypass this limit? I've tried both in the AI Suite III application and by modifying the saved profiles within the application folder, but neither seem to work.
44 REPLIES 44
Dude1070 wrote:
Did you guys use the Fan tuning option in the BIOS or AI Suite? That opens it up for settings.
Yes, but you still can't change or exceed the 75C "critical" temp on the CPU fan headers. That's the whole point of this thread! 🙂
yes its very annoying when pump and fans going up and down, up and down when i have 75C or more on CPU
Rhialto
The title of this thread is a bit wrong as fans are not forced to 100% depending on settings but I'm here to also complain about the 75°C limit as this prevent my build to remain silent when I overclock a bit more but because I really wanted a silent system and that performance wasn't a top priority I lowered like 200MHz so it never reach that 75°C limit.
One reason could be it's because it's reading Tcase and not Tjunction? If it was based on Tjunction, upper fans settings would kick in well before.
Where is Raja? I'd like to hear from ASUS if there is a chance that this limit will be upped a bit in the near future. Personnaly I would be happy with 85°C.
Apologies if this counts as reviving a dead thread, but I just thought I'd mention that as of AI Suite 3.00.10 Beta (likely some time before then, but I only upgraded for the beta), all fan headers now have a custom "Critical Temperature" setting that can be increased up to 100°C. I've currently got my CPU fan to max out at 90 degrees, and under load the loudest thing in my PC is my hard drive.
If someone in the dev team saw this thread and added this little feature in, I'd like to offer them my thanks.
Rhialto wrote:
The title of this thread is a bit wrong as fans are not forced to 100% depending on settings.
Out of curiosity, which settings did you change to enable the fans to max out at a lower speed? The closest I can get is, say, having the fans ramp from 50% at 60°C to 70% at 75°C, but as soon as the temperature goes above the critical temp, the fans immediately ramp to 100%.
Really? Now they need to apply thisin BIOS also, I don't want to install the Suite.
Are you in PWM? Like you at 75°C I set 70% so it never reach 100%. What temp you call critical temp, the 75°C or another hidden temp which trigger 100% for all fans?
To be fair, AI Suite isn't that bad (although I really only use it for the increased fan control options so the extra stuff is a bit bloatware-y).
The "critical temperature" behaviour happens in both PWM and DC control on all fan headers. Say I specify 50% at 60C to 70% at 75C, the fans will slowly ramp up between those two values, but immediately after it hits 75C or goes to 76, the fans ramp to 100%. AI Suite shows this in its UI (I've chosen 75C here for the sake or argument):
70886
The BIOS shows a very similar graph, but I shan't subject you to a phone pic of the UEFI!
And for info, the light grey line is my current setting, which is 100% at 90C.
Rhialto
Yes you are right, all my fans go to 100% past 75°C and ASUS need to let us use a higher value. This is a RoG product after all.
BTW you can take a screenshot from the BIOS with F12.
Same problem, asus pls give us possibility to change 75c cap
Silent_Scone
Super Moderator
There seems to be some confusion here, as a lot of people in this thread appear to be referencing the AI Suite software and UEFI readings to gauge the maximum CPU temperature. This is a Tcase reading that is utilized for fan curve control. If you're hitting 75 Celius Tcase, then your CPU must be running pretty hot. Tcase can be 10-15 degrees lower than DTS temps, sometimes even more. Might be an idea to assess your cooling.
So you are saying that the fan curves in the BIOS are NOT based on CPU temp? This doesn't seem accurate to me. All of my fans will ramp up and down based on CPU temp.
What do you mean by Tcase?
Sorry for the basic question.
Thanks,
Jason
