EXPO making system fail to POST on Strix X870-F (also a workaround)
Taloji
This post can be deleted, link to original down below.
https://rog-forum.asus.com/t5/overclocking-tweaking/unable-to-post-when-expo-enabled-on-x870-f-and-a...
Hello everyone, recently my MSI X870 Tomahawk's CPU fan and pump headers went faulty, sent for a replacement / repair but got a refund instead. I picked up ROG X870-F for the replacement.
I built my pc again, updated BIOS to lastest (0706) and started setting my BIOS up (like Fan curves, RAM).
RAM kit is 2x16GB G.Skill Flare X5 6000MHz 30-38-38 (Hynix A-Die), RAM is on QVL list (Trident Z5 with same timings is listed which has same PCB), motherboard is also listed on G.Skill's QVL list. I have Ryzen 7 7700 for the CPU.
I tried enabling EXPO first to test, i usally adjust my timings later on, but no, system fails to post (DRAM light lights, system shuts down after couple minutes) then boots as safe mode, discarding my settings. EXPO I, II and Tuned all have same results. I've read reports / other posts that a lot of people that have Asus X870 motherboards having RAM issues on later BIOSes.
I tried flashing 0606 to test if it fixes the issue but no luck, having same resuts on 0606.
I've discovered a strange workaround, first of all i'm still on 0606, so i don't know if this will work on 0706. I cleared CMOS with CMOS reset button, i loaded optimized defaults when it booted to BIOS, disabled fast boot on boot section (don't know if this helps).
I turned the EXPO on AMD OC sub-menu, not the Asus Tuning (AI Tweaker), did a save and reboot. After some memory training (around 5 min if i remember correctly) system booted successfully.
I booted to BIOS again to see if i can boot with the timings i've used on Tomahawk. I adjusted timings on AMD OC sub-menu (converted values to HEX since AMD OC menu timings are on HEX) adjusted voltages accordingly then did a save and reboot.
System booted successfully again, running my kit at 6200MHz 30-38-38-30-68 VDD@1.4V,  VSoC@1.2V,  VDDIO and VDDQ@1.35V,  VPP@1.8V . I didn't test the stability since i didn't have much time then, don't know if it's stable, i will try doing some testing later.
I suspected there might be a hardware issue first, but this workaround basically means something is wrong on BIOS, i don't know what went wrong on Asus Tuning section (AI Tweaker).
Taloji
I've tried to create couple posts since posting automatically marked spam.
sonamsaha
आपको अगर दुर्गा चालीसा के शब्दों और उनकी महिमा के बारे में अधिक जानकारी चाहिए तो आप हमारी वेबसाइट पर जा सकते हैं। यहां आपको दुर्गा चालीसा के पूरे शब्द और उनके अर्थ मिलेंगे, जो आपके धार्मिक और मानसिक शांति में मददगार साबित हो सकते हैं। अधिक जानकारी के लिए, कृपया इस लिंक पर जाएं।
