Explaining Offset mode
happening
Hi new to the forum, can one of you lovely dudes explain how to work offset mode, i think i must use this as voltages are been upped when set in manual mode, especially eventual cpu voltage, its been boosted other CPU settings as well. I think my MB is doing this, any settings that can keep the voltages as i set them in the BIOS?
My board is Asus Maximus Hero 6 with the latest BIOS
14 REPLIES 14
Praz
Hello
Enter the additional offset voltage required for stability. Job done. As an example if stock VID is 1.00V and 1.200V is required appromimately 0.200V would be entered in the offset field with the sign option set to positive.
happening
Yea, thanks Praz. What are the best programs to use to monitor the offsets i entered accurately? And is it right to say once the offset is entered in the BIOS that is how the voltages will be?
Raja
The guide you "read" does state to use CPU-Z...
happening
The guide is useless, this forum is not for me, how to delete account?
Raja
Use CPU-Z - if you are not willing to do so then no forum will be for you.
Deleting your account is not possible yourself.
