Directcu ii R9 290x issues, please help!!
WarGasimXD
Hey guys jsut wanted to see if I could get some input from you on regards of my new asus directcu ii R9 290x, I sold my reference design one that was a xfx OC black edition because of the heat issues and figure it was because of it being reference. Well the directcu ii actually runs a little hotter hahhahahh. Idle I'm at 45-48 full load after 30 minutes of BF4 is 83-86, my xfx reference was 39-40 idle and under full load BF4 only 77-80, how is that?? Any ideas beforefor I return it to newegg to get another brand.
below is my setup:
4770k / corsair H110
Corsair air 540 case
corsair platinum 2400 16GB
Corsair ax1200i PSU
13 REPLIES 13
kshafe777
I had the same problem.. and my case is miserable for airflow ( Coolermaster Cosmos SE )... I simply changed the fan settings and now it's awesome... and the fan isn't really that loud on the GPU...
in fact, if I run it for mining I set the fan manually to 85%. keeps it great.. VRAM gets hot while mining, and I mean really hot... but that's about it.
side note... what temps are ok and expected for VRAM?
"Better to try and Fail, then not try at all" ~ Michael Jordan
favorite YouTuber - KDSTech - https://www.youtube.com/channel/UCz0zF8nTziWiBx3v6CNR3yw
Zka17
Level 16
Point a fan on the backside of the card(s) - will help in keeping the VRMs and VRAM cooler... not sure though what is the safe temp for the VRAM specifically, but the lower is better...
WarGasimXD
asus was sent back, newegg gave me a credit and have my new MSI R9 290x lightning on the way 🙂
Well got my lightning hahah way better temps idle 32c and max temps under full load 71 woooweeee
