03-09-2014 05:26 PM - last edited on 03-05-2024 11:27 PM by ROGBot
03-09-2014 08:44 PM
WarGasimXD wrote:
Hey guys jsut wanted to see if I could get some input from you on regards of my new asus directcu ii R9 290x, I sold my reference design one that was a xfx OC black edition because of the heat issues and figure it was because of it being reference. Well the directcu ii actually runs a little hotter hahhahahh. Idle I'm at 45-48 full load after 30 minutes of BF4 is 83-86, my xfx reference was 39-40 idle and under full load BF4 only 77-80, how is that?? Any ideas beforefor I return it to newegg to get another brand.
below is my setup:
4770k / corsair H110
Corsair air 540 case
corsair platinum 2400 16GB
Corsair ax1200i PSU
03-10-2014 02:49 AM
03-10-2014 05:55 AM
WarGasimXD wrote:
Yea I plan on going with a second 290x thats why I went with a 1200i. I got 3 120mm on the front as intake, 1 140mm on the back as exhaust and then the corsair H110 on the top as a exhaust. I have a buddy of mine that has as reference design also and is getting the same temps as my directcuii which doesnt make sense to me and what do you mean by 3.5 stock? if you referring to my CPU, im running @ 4.6
03-10-2014 03:40 PM
03-10-2014 05:04 AM
03-10-2014 03:41 PM
Zka17 wrote:
As I heard, the 290X is running pretty hot... reference design certainly...
The DCII has a factory OC on it? That may explain running at the same temps... however, have you tried to crank up the fan speeds?
Also, play attention to the fact that all the DCII coolers exhausts inside the case... meaning that the hot air leaving the VGA goes through the top mounted radiator if its fans are set to exhaust...
03-10-2014 04:28 PM
Zka17 wrote:
But have you adjusted the fans on the DCII?
No worries with the 1200i - at least you have some headroom now... 🙂
