Crosshair Formula V -Z/Low voltage Warnings
Monroes
Hi guys iam wondering if anyone can help with some issues iam having after my new pc build I finished yesterday,i keep getting low voltage warnings from asus probe II,Computer seems to be running fine had no BSOD or computer restarting ect of any sort so iam a bit baffled to why iam getting these warnings my specs are
Asus Crosshair V Formula Z AMD 990FX (Socket AM3+) DDR3 Motherboard
AMD (Piledriver) FX-8350 4.00GHz (4.20GHz Turbo) Socket AM3+ 8-Core Processor
Corsair Hydro H105 Watercooling Performance CPU Cooler
ASUS DirectCU GeForce GTX 770 OC 2048MB GDDR5 Graphics
Corsair CS750M CS Modular 80 Plue GOLD-RATE 750W 12V Power Supply
12GB DDR3 Samsung 1333mhz Ram (Will be replacing this very soon Don't laugh 😉 )
2TB Hard drive
Screenshot of the warnings and voltages I took
Heres the voltages from my bios
Bios version 2161x64
Vcore +1.344
3.3V +3.312
5V +5.057
12V +11.943
VDDA2.5v +2.508
CPU/NBv +1.164
DRAMv +1.488
HTv +1.204
NB +1.105
SB +1.105
After the 11.19am warning I got I ran 3Dmark 11 all the way through and had no new warnings since then so are these warnings false or do I have something to worry about?
Thanks for your time in-advance if you need any more info then please do ask
Karl
5 REPLIES 5
MeanMachine
Hi Monroes
I have had this issue with AISuite in the past. I know it has some nice features, but Probe ii kept giving out those warnings for me too.
I have now uninstalled the whole Suite as there are better applications for monitoring system voltage and temps. HWMonitor is great.
If you like AISuite as some do, try uninstalling just Probe ii.
Your voltage and temps seem just fine to me.
I have also read that current fluctuations from the PSU can trigger warnings, if it is not up to scratch.
Also do not use AISuite for OCing. Make all changes in Bios only.
We owe our existence to the scum of the earth, Cyanobacteria
My System Specs:
MB:ASUS ROG Crosshair VII Hero/WiFi GPU:EVGA GTX 1080 sc PSU:Corsair AX-1200i
CPU:
AMD R7 2700X Cooler: Corsair Hydro H115i Case: Corsair Carbide 780t
Memory:G.Skill TridentZ F4-3200C14D-16GTZR SSD:Samsung 500GB 960 EVO M.2
[/HR]
Monroes
Hi MeanMachine and thank you for your reply its much appreciated
I really don't plan on OC my cpu as I personally think its just fine for the games I play at the moment plus until I do my homework on it I wouldn't no where to start with the OC'ing :D.
so that being said I will just uninstall probe II,can this be done without uninstalling the whole of AIsuite?
and another quick question off topic about my ram can you make a suggestion on some descent ram that will work well with my current set up.
Thank you so much for your reply and time
MeanMachine
HI Monroes and on further reflection,I don't think you can Uninstall Probe ii without uninstalling the whole Suite or you will have issues.
You might find answers and certain entertainment here: https://rog.asus.com/forum/showthread.php?31680-AI-Suite-II-Weird-Sensor-Warnings&highlight=probe+pr...
I can suggest some decent DIMMs, if you fill out your system specs in your profile please.
My System Specs:
CPU:
[/HR]
Monroes
Hi MeanMachine ive update my spec's in my profile there also in my first posts as well
Hi Monroes Here is a good set, tested by ASUS to be compatible with your MB.
http://www.gskill.com/en/product/f3-14900cl9q-16gbxl
Well priced ATM compared to Corsiar.
My System Specs:
CPU:
[/HR]
