02-06-2014
01:49 PM
- last edited on
03-05-2024
11:45 PM
by
ROGBot
02-06-2014 02:17 PM
02-06-2014 02:31 PM
02-06-2014 02:48 PM
02-06-2014 03:12 PM
chrsplmr wrote:
I would check the connection and wires from the noctua to be sure all is well.
Personally I would have gone the other way, and have, with hwMonitor and Al Suite.
[There is a guide and a 'cleaner' for uninstalling that, btw.]
Next, I would carefully inspect the 4pin for any issues and try a different ps plug if
one is available. [to be on the safe side]
I had many 'spikes' and 'misreadings' from ai suite, so on a fresh install I did away
with it ... and without taking a poll I think that the norm here. .c.
