Corsair H100i help
dj5436
i am running a corsair h100i on a intel i7 2600k and it is all set up and running good but the coolent temp has been staying about 1/2 of the cpu temp example cpu is running at 60 deges Celsius and the coolent will be at about 30-35 any idea why this is happening the thermal past is make a good seal with the cpu any on have any ideas and it is running corsair link
chevy350
Is your pump running at 100%?
AMD 2700X, Asus ROG Strix X470-F, G.Skill Trident Z Neo 3600 (16gbx2), XFX RX 580, NZXT Kraken X62, Corsair 750D, SeaSonic 860W, OCZ RD400, Samsung 950 Pro 256Gb, Intel 520 120Gb SSD
dj5436
yes
chevy350
Are you rrunning any overclock or constant voltage? Maybe an air bubble, is the rad mounted above, beside or below the pump?
