Code dE Led Code on motherboard? Should i be worried?
zaikoni
so i just noticed motherboard error code led is displaying dE? Should i be worried?
Motherboard is asus maximus vii ranger.
zaikoni
UPDATE! the code is AO now after pc restart so it is all good now but Can someone confirm what code that dE was and is it possible that the error code led can so false codes sometimes or the letter just bug out?
Nahrga
Q-code dE means "default" as SoundStage is set to the default setting. You will typically see this when updating/installing the RealTek driver.
So there is nothing to worry about 😉
I was thinking that too man, because i just installed new audio drivers! That explains everything! I just wasn't sure since there was no information about it on manual 🙂 Thank you !
