Chipset water block for Maximus V Formula Z77
Bushwacker
Hi all,
I'll be overclocking pretty much everything and I'll have 2 loops but I was wondering if anyone here put a block on there chipset.
If so, did you see a big difference in temps? I'll list the whole system later.
Basic config:
CPU: 3770K
RAM: 2133MHz
GTX680 4GB X 2
Case: MountainMods Ascension Duality
PSU: Silverstone Strider 1K
MOBO: Maximus V Formula
CPU: i7 3770K
RAM: 32GB Corsair Platinum 2133MHz
Video: 2 X EVGA GeForce GTX 680 Classified
Audio: ROG Xonar Phoebus
Storage 1: OS OCZ REVODRIVE 3 X2 PCI-EXPRESS SSD 240GB
Storage 2: Games OCZ REVODRIVE 3 PCI-EXPRESS SSD 480GB
Storage 3: Data WD Velociraptor WD1000DHTZ 1TB
Cooling: Mix of EK and Swiftech
OS: Win 7 Pro/BackTrack 5 R2
4 REPLIES 4
HiVizMan
Level 40
Just out of interest what are you wanting to cool specifically, the PCH chip?
The key things are the VRM's and they come with the water block attached, pretty much every other controller is now on the CPU.
Thanks for the interest HiVizMan..:)
Well the cpu and VRM's will be on their own loop and the vid cards on their own loop. The ram is Corsairs Platinum series and it does very well on it's own. The Z77 chip-set was the only thing I was wondering about. I havent run an asus board for quite some time so I thought I would get a few recommendations. Im guess it isn't going to generate much heat and that's why I haven't seen it done. Still it does have a heatsink so it must have some heat to it.
CPU: i7 3770K
HiVizMan
Level 40
From an aesthetic point of view it might be worth while but practically the heat generated is marginal. Maybe EK waterblocks do something for the Formula board.
Bushwacker
Those were pretty much my thoughts. With my case you wouldn't really even see it anyway. I do love EK's stuff and they do have full board coverage now for this board. Will have to see how the stock board VRM heatsinks perform before switching to EK though. Thanks for the input.
CPU: i7 3770K
