Can fan xpert 1 control 3 pin case fans?
reg66
as per title: Can fan xpert 1 control 3 pin case fans? i've read that fan xpert II can, but i'm not sure about fan xpert I (i have and will soon be installing maximus iv gene z/ gen3 which comes with ai suite II, not III which has 3 pin fan control-ability in fan xpert II)
welshy46
Apparently not according to this thread. Is it not possible to use Ai suite 3 with the MIVGZ. http://rog.asus.com/forum/showthread.php?21916-Fan-Xpert-does-not-control-optional-chassis-fan
Board: MVIF
CPU: intel core i7 4770k@4.8GHz
GPU: R9 290x
RAM: 16gb Corsair Vengence 2133MHz
SSD: ROG RAIDR 240gb PCI-e SSD
Case: Coolermaster HAF xb
Cooling: custom water loop
Monitor: Asus PB278Q
My build log photo dump
