brick wall 4way sli.
Dark
Guys I have hit a brick wall. Problem is I can't find the 4 way sli bridge in any shops. I have been to 8 shops and no one sells them so is it a one off thing or do I need to find one online and buy it. As its doing my head in I want to go four way sli.
motherboard ASUS Crosshair V Formula
PSU Fractal Design Newton R2 1000W
MemoryRipjaws 16 GB
CaseArmor Mx
CPUAMD Bulldozer FX-8120 8 Core 3.10GHz
Clocked to 4.5GHz
Im a girl 🙂 so be nice as i bite
5 REPLIES 5
kkn
Level 14
try this if nothing else comes up.
http://us.estore.asus.com/index.php?l=product_detail&p=4644
but no promise if it will fitt, since its other boards listed.
Zka17
Level 16
Dark, 4 way SLI on the Crosshair V Formula?! It's not impossible, but it's recipe for trouble... you will need to use the xpander, so the cards won't fit in a regular case... (it's for test benches)
But, if you want to go for it, that one from kin' link will be good - at least, I think so... 🙂
(check this: http://rog.asus.com/17322011/crosshair-v-motherboards/crosshair-v-formula-video-demos/)
Dark
Ok.ill.take.a.look.
MemoryRipjaws 16 GB
CaseArmor Mx
Clocked to 4.5GHz
ACIDpwns
X-ROG
Level 15
The Crosshair V Formula does not support 4-way SLI sorry and the Xpander is not designed for it.
Motherboards that support it will contain a 4-way bridge.
Unless you're benchmarking I would not run 4-way anyway tbh.
