Bluray problem please help!
Cjseanz
Thanks for the advice Zyg :-)!! By the way I had another question for you, my notebook does not comes with blueray so I just bought one but when I put the movie on it's says that the DVD was made in a manner that windows media does not support it, the BD model is a slim type BD E DS4E1S. I move online to check if there is something that it has to be configure but I hadn't fnd anything also I check driver update and it says it was up to date, What should I do?
0 REPLIES 0
