Bluescreen Problem
Sertsch
first off, i only have school-level english so please dont mind if i do some mistakes.
I recently upgraded my PC. Actually i bought a new PC i just kept the Case.
I bought it a month ago and the first bluescreen appeared on 05.01.2014 and then 5 Bluescreens appeared
in the last 3 days.
Motherboard: Maximus VI Formula
CPU: Intel i7 4770k @ 3.5GHz
RAM: 2x4GB Kingston DDR3 1600MHz
Graphics: GTX 780 Ti(Standard cooler)
Temperatures(All in Celsius):
CPU:
-While browsing the internet around 30°-40°
-While Playing(mainly CS:GO) 50°-55°
GPU:
-Internet: 40-42°
-Playing: 80-82°
Before the Bluescreens came i installed a new CPU Cooler
This one: http://www.noctua.at/main.php?show=productview&products_id=34&lng=de&set=1
I had in the last couple of days 5 Bluescreens. I tried some things but now i just dont know what i should do.
-Memcheck
-Removing Memory
-Reinstalled Chipset
-Deleted my newest Services/Programs
I thought before i try everything i find on the internet i should ask you guys if there is something
more specific i could do.
I'm gonna give you the dumpfiles of the 5 Bluescreens. I think i fixed one problem with reinstalling the chipset but i'm not sure( i reinstalled it after the 4th crash)
DMP-Files:
http://www.file-upload.net/gal-72734/cexnv3/1.html
I hope i didn't forget any information you need.
Thank you in advance,
Sertsch
kevvy
hi, are you sure you did,nt unseat your i7 when you put new cooler in, just a thought m8
MOTHERBOARD : ROG CROSSHAIR V FORMULA... bios 1703
MONITOR : AOC 24 INCH 144HZ
PROCESSOR : AMD FX 8350 - 4.4 Ghz
RAM:CORSAIR : XMS 16 GIG 1760 hz
COOLING : DARK ROCK PRO 3
GRAPHICS : ROG GTX TWIN 760 STRIKERS IN SLI
PSU : CORSAIR HX750
X PREDATOR CASE : IN WHITE
Cruicial 256 Gig SSD OS
Cruicial 128 Gig SSD GAMING
FANS.2 Aerocool Dead Silence 140 mm Red top exhaust
2 Aerocool Dead Silence 140 mm Red 1 front intake1 rear exhaust1 Aerocool 200 mm front intake
WINDOWS 7 Ultimate 64 bit
HiVizMan
Level 40
Remove the Cooler and re-fit. I think you have a mount issue.
