Bios LED won't stop flashing
HarryM
Hi everyone,
Right now i am trying to flash my bios to the latest .CAP bios but when i start the bios easy flash bios the bios LED on my Asus Rampage IV Extreme doesn't stop flashing and i don't know what to do now. Do i take out the USB stick? Do i try the bios updater again? I really don't know.
Thanks in advance for any replies
9 REPLIES 9
chrsplmr
Level 18
If you have the bios on a fresh fat 32 USBdrive .. easy flash ? (bump).c.
Retired
Not applicable
how long has it been blinking..
Be a little careful when doing this, a interrupted bios update, can result in a faulty bios.. and major errors.
it blink for a while (around 1 min maybe), slow, a little faster, fast. DONE
HarryM
i Just tried that and the LED for ROG connect and the bios LED are both flashing fast and they wont stop
Chino
Level 15
danavsbelly
yeah,Just tried that and the LED for ROG connect and the bios LED are both flashing fast and they wont stop
HarryM
it was a brand new motherboard and i am trying to flash the bios to 3404 i have left the computer for hours and the light is still flashing. Also the computer wont post and the red DRAM LED turns on whenever i try to turn on the computer. (that is why i am trying to flash the bios, to find out if that is the problem but i am having problems doing that aswell...)
Krindor
Level 11
Is this the first BIOS update for the board? If so please take a look at this guide, the RIVE requires a CAP converter as it is using ROM BIOS first:
http://event.asus.com/2012/mb/USB_BIOS_Flashback_GUIDE/
| Chassi: Phantom Fulltower White Edition | Mobo: Maximus V Extreme | CPU: i7 3770k
| Memory: 2x8gb G.Skill Trident X 2400mhz | GPU: PNY Geforce GTX 670 | PSU: NZXT Hale 90 750w
| SSD: Intel 120gb 330 series (OS) | Intel 120gb 330 series (Games n stuff)
| Monitor: LG 29EA93 | Cooling: Custom Loop
HarryM
I have already done the cap update and it appeared to be successful
ResHacker
It seems that that if you have the ROG connect cable plugged in on the motherboard, the update will blink forever...
