12-09-2016
12:35 AM
- last edited on
03-05-2024
11:00 PM
by
ROGBot
12-17-2016 05:06 AM
12-22-2016 04:06 PM
Itzycharles wrote:
Thanks for your tutorial. looks interesting. Question Why 43 in the mim and max on the CPU ratio. Disable the Q-Fan for max performance will put the fans on full speed? *I get the part adding the ram timings from factory. I have to change my cooler these week (115i) since my deep cool on my 6700K is not doing the correct job. A friend of mine help to make my processor on the Asus work. On he GA, I was on 4.6 at 1.381 ultra stable. here took me more more time 3 RMA and testing a Alpha that appears to be ok I think. No Asus apps are install. (known issues) As soon I recibe my 4 RMA..... I will start again with all os and OC again.*
12-31-2016 01:44 PM
01-05-2017 06:08 AM
Michael-i7 wrote:
I have the i7 6700k in an Asus z170 Deluxe I have mine overclocked to 4.5Ghz with 1.31v and I have my min/max cache 45 as well and I'm stable as F. And I must point out that with ddr4 DO NOT put the voltage at 1.5v I have my ram overclocked to 3333Mhz with 1.355v ddr4 is 1.2-1.35v ddr3 was 1.5 You may not kill your ram that way but the chances are very good that you will there is no need to put ddr4 over 1.35-1.4 especially at a meager speed of 2800mhz even 4000 mhz ddr4 isnt rated at 1.5v
