01-21-2024 02:54 PM
Hi, i have problems with my audio (crackling/popping) when i put the XMP, i have 3200mhz and 1.35v, but the VDDQ_TX seems too low, it is 1.2v and needs to be on 1.3v.
I saw some guy post that said he raised the VDDQ voltage to 1.3v and the audio problem is gone.
Now the problem is, i dont find the VDDQ_TX voltage on my BIOS.
I have the asus bios but the normal one not the rog.
01-21-2024 10:43 PM
Hi @FacundoQ
Which board?
Extreme Tweaker > Advanced Memory Voltages.
If raising this helps, it's possible the system might not be stable. Ensure to update to the latest audio drivers available on the support site, also.
01-22-2024 12:24 AM
Hi, my board is H610m-k
I don't have the section "Extreme Tweaker" Just Ai Tweaker and i don't find "Advanced Memory Voltage".
My driver audio is updated.
The headset turns off itself, rgb goes crazy, crackling audio.
I tested on another pc and it works fine.
