03-24-2013 05:36 PM - last edited on 03-06-2024 09:39 PM by ROGBot
03-24-2013 06:07 PM
03-24-2013 06:26 PM
03-24-2013 07:02 PM
03-25-2013 04:05 AM
Zka17 wrote:
Is your Windows Power Plan at High Performance? That would keep the speed at it's max...
03-25-2013 04:09 AM
MultiDoc wrote:
This:
Check the power plan you have in Windows and change it either to balanced or go into advanced settings for the High Performance one andchange the "minimum CPU" value to 5%
03-25-2013 04:21 AM
davidt wrote:
I tried that, didn't change the core speed, still the same at 3900 MHz idle and load
03-25-2013 11:02 AM
MultiDoc wrote:
Hmmm... change the power plan to "balanced", apply and restart. Then go and change to "high performance" but also change the "minimumcpu" to 5%, apply and restart. Does it help ?
