10-06-201302:14 AM - last edited on 03-06-202407:25 PM by ROGBot
Hello I am trying to install the Ai Suite III on my pc ... i have Hero Z87 motherbord I cant install it i was trying evryithing from serching the web and this forum ... The install not starting at all even when i run on admin and unlock all the files from installation folder ... i use Cceaner and AI Suite II uninstall cleaner safe mode and evrything that i can find ... i am really want this program and its anoying that i cant install it !
thanx for your help and sorry for my english ( is bad :< ) Guy
Please list your OS and where you downloaded the Application from. I would suggest you use the AISuite that came with your motherboard, the support DVD.
My OS is windows 7 64 bit I download the Ai suite from asus site All my drivers download from asus site I cannot use the disk cuz I don't have any cd-rom ( working one )
Ah that does put a spanner in the works. There is a sticky post about how to install the AISuite application all I can suggest is using that as a start and then report back if you get stuck.
